Support Resource
The Manage blocked Esri apps and capabilities setting in ArcGIS Online and ArcGIS Enterprise (located under Organization > Settings > Security) is designed to control whether ArcGIS Pro can be licensed through an ArcGIS organization designated as the licensing portal. It is not a comprehensive mechanism for controlling the ability to connect and other privileges when connecting to a portal from ArcGIS Pro.
When ArcGIS Pro is blocked by selecting it under Blocked Esri apps and capabilities:
Organizations that need to restrict what ArcGIS Pro users can do after connecting to a portal should consider using custom roles and privilege management. These controls govern what authenticated users can do within the portal regardless of how ArcGIS Pro itself is licensed.
Article ID: 000043799
Get help from ArcGIS experts
Start chatting now
