BUG
BIM Cloud Connection downloads Revit file as an unsupported file
Last Published: January 22, 2021
BIM Cloud Connection zips files when downloading them from BIM 360. Because of this, ArcGIS Pro cannot directly read the file and display a message of an unsupported file. This behavior only happens when the following criteria are met.
  • The Revit file is linked.
    • BIM 360 is using the design and collaboration function.
  • The total size of the Revit file plus the linked files is at or over the max limit.
Cause
BIM Cloud Connection zips files by mistake.
Workaround
Esri is working to find a solution in the next release. In the meantime, please use the following as a workaround.
  1. Close ArcGIS Pro.
  2. Using File Explorer navigate to the folder where the BIM Cloud Connection downloaded the Revit file.
  3. Change the extension of the Revit file from .RVT to .ZIP
image of downloaded file
image of renamed file
  1. Extract the data from the folder. The folder contains all the linked files associated to the main downloaded file.
image of extracted files
Using the Get Status command
  • The Get Status works as designed.
Using the Refresh from Source command
  • The refresh command works, but downloaded data is again in the .zip format with an .rvt extension. To resolve this issue, follow the steps outlined above in the workaround
Article ID: 000024968
Software:
  • ArcGIS Pro 2 7 x
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
