PROBLEM
If an ArcGIS Enterprise component's utility tool is run incorrectly from the command line, this may result in a failure to run the tool or an error message. It has been observed that subsequent attempts to run the tool may fail.
When navigating to the folder of the utility tool, for example C:\Program Files\ArcGIS\Portal\tools\security\enableArcgisLogins, and observing the Windows batch file (the tool itself in a .bat format), the file size is 0KB.
The file size for a utility tool .bat file should 1KB or greater.
There are two approaches to resolve this issue:
Article ID: 000042540
Get help from ArcGIS experts
Start chatting now
