ERROR
When attempting to set the StandardizingRules property of the Standardizer, the following error message is received:
Automation Error: The object invoked has disconnected from its clients.
One or more required support files are missing from the directory containing the StandardizingRules file.
When deploying MO2 applications that use the Geocoder, make sure to include the following support files (found in the GeoRules folder):
prefix.tbl
direct.tbl
expand.tbl
suffix.tbl
related *.cls, *.dct, and *.pat files
Also, make sure all deployed GeoRules files are installed to a single directory on the target machine.
Article ID:000001948
Get help from ArcGIS experts
Download the Esri Support App
