HOW TO
Automate the export of rasters from a geodatabase raster catalog
Last Published: September 2, 2021
Summary
GIS managers and administrators sometimes need to automate the process of exporting rasters from geodatabase raster catalogs to raster datasets on disk. Instructions provided describe how to do this.
Procedure
The below Python script demonstrates how to automate the export of raster datasets from a geodatabase raster catalog to a raster dataset on disk. The background value is also set to zero in the below script.
Modify the parameters below according to the environment:
workspace = r"Database Connections\lclinton2_SQL08_R2.sde\sde101.SDE.Prasanta"
outras = r"C:\Data\outrasters"
Code:
import arcpy, os, string
def ExtractRasterFromRC(workspace,outras):
    count = arcpy.GetCount_management(workspace)
    str_cnt = str(count)
    int_cnt = int(str_cnt)
    cnt = 1
    while cnt <= int_cnt:
        raster = workspace + os.sep + "Raster.OBJECTID=" + str(cnt)
        name = "tiff_" + str(cnt) + ".tif"
        name_out = outras + os.sep + name
        print ("Reading {0}".format(raster))
        arcpy.CopyRaster_management(raster,name_out,"DEFAULTS","0","0","","","8_BIT_UNSIGNED")
        print ("Copied {0}".format(name_out))
        cnt += 1
if __name__=="__main__":
Article ID: 000011753
Software:
  • ArcMap 10 6
  • ArcGIS Pro 2 8 x
  • ArcGIS Pro 2 7 x
  • ArcMap 10 x
  • ArcMap 10 7
  • ArcGIS Pro 2 x
  • ArcMap 10 8
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
