HOW TO
Automate running ArcGIS Data Store command utilities
First Published: February 27, 2024
Last Published: February 27, 2024
Summary
To monitor and archive the ArcGIS Data Store health and status, it may be beneficial to automate running an ArcGIS Data Store command utility, like describedatastore, and save the output to log files.
Procedure
This can be done by following the steps below:
  1. On the ArcGIS Data Store machine, if a Python environment is not already installed, installĀ Python 3.x.
  2. Create a .py file and paste the below script in it:
import os
from datetime import datetime
time = datetime.now().strftime("%Y-%m-%d-%H-%M-%S")
DescribeDataStoreBatFile = r"C:\Program Files\ArcGIS\DataStore\tools\describedatastore.bat"
OutputResultsFolder = r"C:\DescribeDataStoreResults"
DescribeDataStore = os.popen(DescribeDataStoreBatFile)
DescriptionOutput = DescribeDataStore.read()
DescribeDataStore.close()
OutputFile = open(os.path.join(OutputResultsFolder,f"Output{time}.log"),"w+")
OutputFile.write(DescriptionOutput)
OutputFile.close()
  1. Edit the DescribeDataStoreBatFile parameter to point to the path of the .bat file.
  2. Edit the OutputResultsFolder parameter to point to the folder path where you want the log files to be generated.
  3. Automate running the script using Windows Task Scheduler.
If you have any issues with permissions, or if the script creates empty files, please consult your IT department before doing the following steps.
  1. In the Local Security Policy app, go to User Rights Assignment, log on as a batch job, and add the ArcGIS service account.
  2. In Edit Local Users and Groups > Groups > Administrator Groups. add the ArcGIS service account.
Article ID: 000031821
Software:
  • ArcGIS Data Store
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
