HOW TO
Reconciling and posting versions in a multi-tiered versioning workflow such as secondary to primary to default followed by compress is a typical workflow performed by GIS administrators or managers.
Note: This article pertains to ArcGIS version 10.0 only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed. ArcGIS software features were deprecated, rather than immediately removed, to provide customers with backward compatibility and give as much advance notice as possible to adopt newer technology.
The Python script below provides a method for automating the reconcile, post, and compress workflow. The workflow assumes three tiers (default > primary > secondary), such that secondary versions are reconciled to primary versions and primary versions are reconciled to default.
Note: The script also compresses the geodatabase to state 0, deletes all versions except DEFAULT and re-creates the secondary versions.
vTree = {'SDE.Parent':'SDE.Child','SDE.QA':'SDE.Edit'}
workspace = r"Database Connections\MXD2.sde"
defaultVersion = "sde.DEFAULT"
logName = "RecPostLog.txt" logName2 = "RecPostDefaultLog.txt" logName3 = "CompressLog.txt" logWorkspace = r"C:\temp"
#Reconcile and posting versions at 10.0 import arcpy, os, sys, string #Populate parent and child versions in the following manner('Parent':'Child', etc). DO NOT LIST DEFAULT vTree = {'SDE.Parent':'SDE.Child','SDE.QA':'SDE.Edit'} #Reconcile and post child versions with parent def RecPostNonDefault(workspace,logWorkspace,logName): outLog = open(os.path.join(logWorkspace, logName), 'w') for key, val in vTree.iteritems(): arcpy.ReconcileVersion_management(workspace, val, key,"BY_OBJECT", "FAVOR_TARGET_VERSION", "NO_LOCK_AQUIRED", "NO_ABORT", "POST") print "Reconciling and posting {0} to {1}".format(val, key) outLog.write("Reconciling and posting {0} to {1}".format(val, key)) outLog.write("\n") outLog.close() del outLog, key, val #Reconcile and post with parent def RecPostDefault(workspace,logWorkspace,logName2,defaultVersion): outLog = open(os.path.join(logWorkspace, logName2), 'w') #Reconcile and post parents with DEFAULT for key, val in vTree.iteritems(): arcpy.ReconcileVersion_management(workspace, key, defaultVersion,"BY_OBJECT", "FAVOR_TARGET_VERSION", "NO_LOCK_AQUIRED", "NO_ABORT", "POST") print "Reconciling and posting {0} to DEFAULT".format(key) outLog.write("Reconciling and posting {0} to DEFAULT".format(key)) outLog.write("\n") outLog.close() del outLog, key, val def DeleteChildVersions(workspace): arcpy.ClearWorkspaceCache_management() for key, val in vTree.iteritems(): arcpy.DeleteVersion_management(workspace, val) print "Deleted {0}".format(val) def DeleteParentVersions(workspace): arcpy.ClearWorkspaceCache_management() for key, val in vTree.iteritems(): arcpy.DeleteVersion_management(workspace, key) print "Deleted {0}".format(key) #Compress database def Compress(workspace,logWorkspace,logName3): arcpy.ClearWorkspaceCache_management() outLog = open(os.path.join(logWorkspace, logName3), 'w') arcpy.Compress_management(workspace) print ("Compressed database {0}".format(workspace)) outLog.write("Compressed database {0}".format(workspace)) outLog.close() def RecreateVersions(workspace, defaultVersion): for key, val in vTree.iteritems(): arcpy.CreateVersion_management(workspace,defaultVersion, key[4:], "PUBLIC") print "Created version {0}".format(key) arcpy.CreateVersion_management(workspace, key, val[4:], "PUBLIC") print "Created version {0}".format(val) if __name__=="__main__": workspace = r"Database Connections\MXD2.sde" defaultVersion = "sde.DEFAULT" logName = "RecPostLog.txt" logName2 = "RecPostDefaultLog.txt" logName3 = "CompressLog.txt" logWorkspace = r"C:\temp" RecPostNonDefault(workspace,logWorkspace,logName) RecPostDefault(workspace,logWorkspace,logName2,defaultVersion) DeleteChildVersions(workspace) DeleteParentVersions(workspace) Compress(workspace,logWorkspace,logName3) RecreateVersions(workspace, defaultVersion)
Article ID: 000011679
Get help from ArcGIS experts
Download the Esri Support App
