HOW TO
GIS managers, DBAs, and administrators sometimes need to automate workflows, such as enabling geodatabases. Instructions provided describe how to do this using a Python script.
The Python script below demonstrates how to create a connection file and enable a geodatabase.
Note: To run the Enable Enterprise Geodatabase geoprocessing tool, you must have ArcGIS Desktop (Desktop Standard or Desktop Advanced), ArcGIS Engine Geodatabase Update, or ArcGIS Server installed on the computer from which you connect to the database and enable geodatabase functionality.
Modify the below parameters according to the environment:
temp = r"C:/temp" auth_file = "C:/Authorizationfile/aut101/Server_Ent_Adv.ecp" Connection_File_Name = "Nidhi_oracle2.sde" database_platform = "ORACLE" instance = "lclinton2/testoracle" database = "" account_authentication = "DATABASE_AUTH" username = "sde" password = "sde" save_user_pass="TRUE" dba_username = "sys" dba_password = "manager"
Python script:
import arcpy, os, sys, string def CreateGeoDB(temp,auth_file, Connection_File_Name,database_platform,instance,database,account_authentication,username,password,save_user_pass,dba_username,dba_password): #Create connection file arcpy.CreateDatabaseConnection_management(temp,Connection_File_Name,database_platform,instance,account_authentication,username,password,"SAVE_USERNAME","","","TRANSACTIONAL","","") print "Created sdeconnection" arcpy.EnableEnterpriseGeodatabase_management(temp + os.sep + Connection_File_Name, auth_file) print "Enabled database" if __name__ == "__main__": temp = r"C:/temp" auth_file = "C:/Authorizationfile/aut101/Server_Ent_Adv.ecp" Connection_File_Name = "Nidhi_oracle2.sde" database_platform = "ORACLE" instance = "lclinton2/testoracle" database = "" account_authentication = "DATABASE_AUTH" username = "sde" password = "sde" save_user_pass="TRUE" dba_username = "sys" dba_password = "manager" CreateGeoDB(temp,auth_file, Connection_File_Name,database_platform,instance,database,account_authentication,username,password,save_user_pass,dba_username,dba_password)
Article ID: 000011776
Get help from ArcGIS experts
Start chatting now
