HOW TO
GIS managers and administrators sometimes need to automate the creation of feature classes based on a template. The steps below describe how to do this.
Code: #Database connection file path conn = r"Database Connections\Loop.sde" #Name of feature classes to be created FCList = ["State_Px1","Ozonex1","Birajx1"] #Name of fields to be populated for first feature class fields1 = ['State', 'State_Code', 'Xfield'] #Name of fields to be populated for second feature class fields2 = ['Areax', 'Ozone_Amt', 'S3'] #field types for feature class one fieldType1 = ["TEXT", "DOUBLE", "LONG"] #field types for feature class two fieldType2 = ["TEXT", "DOUBLE", "LONG"]
Code:
import arcpy, string, os
def CreateFeatureClass(conn, fc,logWorkspace,logFC):
outLog = open(os.path.join(logWorkspace, logFC), 'w')
arcpy.CreateFeatureclass_management(conn,fc,"POLYGON","","DISABLED","DISABLED","GEOGCS['GCS_WGS_1984',DATUM'D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]];-400 -400 1000000000;-100000 10000;-100000
10000;8.98315284119522E-09;0.001;0.001;IsHighPrecision","","0","0","0")
print "created fc {0}".format(fc)
outLog.write("Created feature class {0}".format(fc))
outLog.write("\n")
outLog.close()
def AddFields(conn_fc, fieldList, fieldType):
for field, ftype in zip(fieldList,fieldType):
arcpy.AddField_management(conn_fc,field,ftype,"","","","","NULLABLE","NON_REQUIRED","")
print "Added field {0} for fc: {1}".format(field, conn_fc)
if __name__=="__main__":
#Variables to populate
logFC = "CreatedFC_log.txt"
logWorkspace = r"C:\temp"
fcpy_list = []
#Create Feature Classes
cnt = 0
for fc in FCList:
CreateFeatureClass(conn, fc, logWorkspace,str(cnt) + logFC )
fcpy_list.append(fc)
cnt += 1
del fc
conn1_fc = conn + os.sep + fcpy_list[0]
conn2_fc = conn + os.sep + fcpy_list[1]
conn3_fc = conn + os.sep + fcpy_list[2]
AddFields(conn1_fc, fields1,fieldType1)
AddFields(conn2_fc, fields2,fieldType2)
AddFields(conn3_fc, fields2,fieldType2)
Article ID: 000011744
Get help from ArcGIS experts
Start chatting now
