ERROR
Attribute Update: An unexpected failure occurred. Out of memory [table_name]
Error Message
Adding an attachment to an individual feature that is over 500 MB results in the following error (the table name is variable):
[O-Image]
Cause
Data loaded into attachments must fit into memory. ArcGIS Desktop is a 32-bit application, so it is limited to 2 GB. The memory required for loading must be continuous. So the size limit for an attachment is dependent on how much continuous memory is available. With most configurations this results in a limit around 500 MB per individual file.
Solution or Workaround
Depending on the files being worked with, there may no workaround. However, certain types of files can be handled differently to reduce their size:
  • If the file is a photo, various programs can be used to resize the image or reduce the image resolution.
  • On video files, video editing software can be used to break the videos down to a more manageable size (for example, an hour video could be reduced to two thirty-minute videos).
    This approach could also be used with Adobe PDFs and related files.
Article ID: 000011937
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
