BUG
When attempting to enable geodatabase archiving for a feature class in Oracle stored as st_geometry, a -51 underlying DBMS error can be encountered.
This error is only encountered if the feature class being archive-enabled was previously migrated from SDEBINARY or Oracle Spatial and the feature class contains mixed low and high precision geometries.
Newly created feature classes in Oracle stored as st_geometry do not encounter this error because all the data is stored in high precision.
Executing the Geoprocessing Migrate Storage tool or the sdelayer -o migrate command to migrate an SDEBINARY or Oracle spatial feature class that has a mixed precision, results in the migrated feature class with mixed precision.
To detect if a feature class has mixed precision, execute the sdelayer -o describe command. This example demonstrates describing a feature class named 'parcels', stored as SDEBINARY with the SDELOB type prior and after being migrated to st_geometry.
Code:
C:\>sdelayer -o describe -u forrest -p forrest -i 5151 -l parcels,shape -s server
ArcSDE 9.3.1 for Oracle10g Build 315 Thu Feb 12 12:00:43 2009
Layer Administration Utility
Table Owner : FORREST
Table Name : PARCELS
Spatial Column : SHAPE
Layer id : 874
Entities : a+
Layer Type : SDE-LOB
I/O Mode : NORMAL
Autolocking : Enabled
Precision : High (Mixed)
User Privileges : SELECT, UPDATE, INSERT, DELETE
Layer Configuration: SDELOB
Code:
Table Name : TEST4
Layer id : 874
Entities : a+
Layer Type : Extended SQL Type
I/O Mode : NORMAL
Layer Configuration: ST_GEOMETRY
Article ID:000010511
Get help from ArcGIS experts
Download the Esri Support App
