ERROR
This error occurs when clicking the Make Default button on the Customize dialog box:
Assertion: "Project has filename" failed at line 1581 of file"../appl/project.c"
Your system doesn't have the $HOME environment variable defined.
Note: If ArcView cannot find a $HOME variable on your system, it will use the $TEMP variable instead.
Article ID:000003833
Get help from ArcGIS experts
Download the Esri Support App
