Frequently asked question
Are incoming GPS coordinates projected to the Map's coordinate system?
Answer
Yes. ArcPad does the following to incoming GPS coordinates:
1. Transforms the GPS coordinates from the GPS datum (usually WGS84) to the Map's datum. This only occurs if the GPS datum does not match the Map's datum.
The GPS datum is set in the ArcPad Options dialog box: Protocol page.
ArcPad's datum transformations are stored in the file apDatums.dbf.
2. Projects the geographic GPS coordinates to the Map's projection. This only occurs if the Map uses projected coordinates.
Article ID:000006712
Software:
  • ArcPad Prev
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
