Frequently asked question
Are Computed/Virtual columns supported in an Enterprise environment in ArcGIS?
No, Computed Columns (SQL Server) and Virtual Columns (Oracle and PostgreSQL) are not supported in ArcGIS geodatabases.
A computed/virtual column is populated dynamically and is not physically stored with the table. Computed/virtual columns are read-only. The geodatabase does not support auto-populated fields such as computed columns or automatically incrementing fields.
Database tables utilizing these columns can be viewed in ArcGIS using Query Layers or Database Views, but the tables or feature classes cannot be registered with the geodatabase. If a computed/virtual column is added to a table that is already registered with the geodatabase, the table cannot be enabled for archiving or registered as versioned for editing.
Article ID: 000008488
Software:
  • ArcMap
  • ArcGIS Pro 1 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
