When trying to open a PMF in ArcReader installed on a Microsoft Surface Pro, the software crashes with the following message:
"ArcReader.exe has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available."
![[O-Image] ArcReader Stopped Working](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000011829/00N39000003LL24-0EM39000000wdQT.png)
Cause
There is a conflict with graphics card driver 9.17.10.3062 (dated 3/8/2013).
Solution or Workaround
Roll back the driver to 9.17.10.2867 (dated 12/5/2012) resolve the issue.
- Go to Control Panel > Display.
- In the Display section, click the Adjust Resolution link on the left.
- In the Screen Resolution section, click the Advanced Settings link in the middle right of the dialog. This opens the graphics card properties dialog box.
- From the Adaptor tab, click the Properties button.
- Click the Driver tab. Click Roll Back Driver, the third button, if driver 9.17.10.3062 is installed.
- In the new dialog box, click Yes to confirm rolling back the driver.
