BUG
ArcPad's ArcPadPrefs.apx file is not saved on the Magellan MobileMapper CX (MMCX) mobile device after turning the device off and then on again.
The MMCX device only retains files saved under '\My Device' path.
Any files saved under '\My Document' path in memory is wiped out once the device is turned off.
Upon startup, ArcPad looks for .apx files at certain searching paths. If the file is not there, it assumes there is no custom settings saved and opens with default settings.
Article ID:000009654
Get help from ArcGIS experts
Download the Esri Support App
