ERROR
ArcObjects WriteOnly Properties are not accessible and throw “BC30643 Property is of an unsupported type” compile error in Microsoft Visual Studio 2015 with VB.NET
Error Message
When trying to compile ArcObjects code to set an interface property that has an input parameter (typically the parameter is an index), Visual Studio 2015 returns  the following compiler error:
Error:
BC30643 Property ‘ESRI.ArcGIS.xxx’ is of an unsupported type
Visual Basic
Error:
BC30643 Property is of an unsupported type (Visual Basic)
Here is an example using IFieldsEdit.
        Dim pFieldEdit As IFieldEdit = pField
        pFieldEdit.Name_2 = "OBJECTID"
        pFieldEdit.AliasName_2 = "FID"
        pFieldEdit.Type_2 = esriFieldType.esriFieldTypeOID
        Dim pFieldsEdit As IFieldsEdit = pFields
        pFieldsEdit.FieldCount_2 = 2
        pFieldsEdit.Field_2(0) = pField
C#
Error:
CS1546 Property, indexer, or event is not supported by the language,
try directly calling accessor method...
            IField field = new Field();
            IFieldEdit fieldEdit = field as IFieldEdit;
            fieldEdit.Name_2 = "OBJECTID";
            fieldEdit.AliasName_2 = "FID";
            fieldEdit.Type_2 = esriFieldType.esriFieldTypeOID;
            IFields fields = new Fields();
            IFieldsEdit fieldsEdit = fields as IFieldsEdit;
            fieldsEdit.Field_2[0] = field;
Cause
Several WriteOnly properties with input parameters are affected and inaccessible with Visual Basic in Visual Studio 2015 and include, but may not be limited to:
  • IFieldsEdit
  • IGeometryDefEdit
  • ITableSort
  • ISpatialJoin
  • ISymbolCollectionElement
Solution or Workaround
Workaround for Visual Basic
For the issue with Visual Basic, use Visual Studio 2013 to compile and debug the code.
Workaround for C#
When using C#, following the compiler output, rewrite the code as shown below:
            //fieldsEdit.Field_2[0] = field;
            fieldsEdit.set_Field(0, field);
This fixes the compiler error.
Article ID:000001060
Software:
  • ArcObjects SDK Microsoft NET Framework
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
