BUG
While running the ArcIMS Z39.50 Connector, the ArcIMS Author, Designer, Manager and Administrator applications may fail to run properly or not start.
The logging window that appears when the ArcIMS Z39.50 Connector is started is using system resources in a way that causes other Java applications to fail.
Code:
# declare your logging appenders here
log4j.rootLogger=DEBUG, stdout, JavaWindow, Access, Debug
Code:
log4j.rootLogger=DEBUG, stdout, Access, Debug
Article ID:000007048
Get help from ArcGIS experts
Download the Esri Support App
