PROBLEM
ArcGIS Web Adaptor installation loops due to missing IIS components
First Published: December 11, 2025
Last Published: June 25, 2026
While installing the ArcGIS Web Adaptor, sometimes the installer repeatedly prompts for missing IIS components.
Cause
Even after installing all prerequisite components, such as Microsoft Web Deploy and the ASP.NET Core Runtime, the ArcGIS Web Adaptor may fail to install if the required IIS components are missing from the operating system. This can result in the installer repeatedly prompting for missing components.
Solution or Workaround
  1. Verify that your system meets all Windows operating systems (OS) requirements for the ArcGIS Web Adaptor. For example, Windows 11 Home Edition lacks the necessary IIS components that can cause the installation to loop. Use a compatible OS edition with full IIS support.
  2. Refer to the web help topic: Manually enable IIS Components, and make sure that the required IIS components are enabled
identifying missing components
installing missing components
enabling Windows features
Article ID: 000039528
Software:
  • ArcGIS Enterprise
  • ArcGIS Web Adaptor
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
