ERROR
When attempting to connect to an ArcGIS Enterprise deployment from ArcGIS Survey123 on an Android device, users may encounter the following error message:
SSL handshake failed (6)
Error 6: The certificate has expired
This issue prevents users from successfully authenticating and accessing web maps, feature layers, or other resources published in the ArcGIS Enterprise environment.
A common cause of this behavior is an expired SSL/TLS web server certificate used by the ArcGIS Enterprise deployment. ArcGIS Survey123 relies on a secure HTTPS connection to communicate with ArcGIS Enterprise. If the server certificate has expired, Android devices will reject the secure connection because the certificate can no longer be validated.
Certificates issued by a trusted Certificate Authority (CA) are essential for establishing a trusted communication channel between client applications and ArcGIS Enterprise. Once the certificate expires, the TLS handshake fails, preventing ArcGIS Survey123 from establishing a secure connection and resulting in the error described above.
This issue can affect all ArcGIS Enterprise components exposed through HTTPS, including Portal for ArcGIS, ArcGIS Server, ArcGIS Web Adaptor, and other applications, depending on the deployment architecture.
The issue can be resolved by replacing the expired SSL/TLS certificate with a new, valid certificate issued by a trusted Certificate Authority (CA). After the certificate has been renewed and correctly configured, all ArcGIS Enterprise components should trust the updated certificate chain, allowing ArcGIS Survey123 to establish a secure connection successfully.
The following steps describe how to import and configure the new SSL/TLS certificate across the ArcGIS Enterprise components:
https://machine.domain.com/<webadaptor>/portaladmin
https://machine.domain.com:7443/arcgis
Confirm that the browser reports a valid HTTPS connection and that the new CA-issued certificate is presented.
https://gisserver.domain.com:6443/arcgis/admin
After the certificate has been replaced in both Portal for ArcGIS and ArcGIS Server, verify the following:
Article ID: 000042892
Get help from ArcGIS experts
Start chatting now
