ERROR
ArcGIS Server print service and caching controller crash when VMWare 12.5 is installed
Last Published: June 23, 2025
Error Message
Customers have been reporting that ArcGIS Enterprise print services, default or custom, unexpectedly crash when VMWare Tools 12.5 is installed on the same machine as the ArcGIS Server component. When investigating, users may see the following messages in the ArcGIS Server logs:
  • <Msg time="2024-10-30T13:51:40,397" type="SEVERE" code="9000" source="Rest" process="1360" thread="1" methodName="" machine="xyz.com" user="" admin="" requestID="18e643d2-02cd-46d1-89d4-9e1704a2c92a">Error performing execute operation Error handling service request :Could not service request.</Msg>
  • <Msg time="2024-10-30T14:04:15,311" type="SEVERE" code="7551" source="Server" process="1360" thread="26" methodName="" machine=" xyz.com " user="" admin ="" requestID="a868451b-3ec3-4e7e-8d15-ba57d267ae2d">Instance of the service 'Test/ExportWebMap.GPServer' crashed. Please see if an error report was generated in 'D:\arcgisserver\logs\</Msg>
  • <Msg time="2024-10-30T14:04:26,607" type="SEVERE" code="7553" source="Server" process="1360" thread="26" methodName="" machine=" xyz.com " user="" admin ="" requestID="a868451b-3ec3-4e7e-8d15-ba57d267ae2d">The containing process for 'Test/ExportWebMap' job 'j684cfa28396b441999c4e9b3130cf09c' has crashed.</Msg>
There have also been reports of the caching controller crashing.
This knowledge article describes the nature of the error as well as two options to resolve it.
Cause
The cause of this issue is a known VMWare defect involving the vm3dgl64.dll file used by the OpenGL driver packaged with VMware Tools 12.5.0. Process Monitor logs report that vm3dgl64.dll receives many read requests from the ArcSOC.exe process that manages the PrintingTools service just before it crashes. vm3dgl64.dll is a commonly distributed library with VMWare tools that interfaces with many applications, including ArcGIS Server.
Solution or Workaround
There are two possible solutions for this issue:
  • Roll back to VMWare Tools 12.4.5 until a newer version is released. As users report, this has been the most common and simplest solution to avoid the crash.
  • Implement one of the workarounds developed by the owners of VMWare, Broadcom. The workarounds, as described in their knowledge base, include:
    • Disable the use of llvmpipe by adding this virtual machine config option to the VM's VMX file: guestinfo.svga.disableLLVMPipe=TRUE
    • Set a system environment variable SVGA_ALLOW_LLVMPIPE=0
June 11th 2025 Update: Broadcom has released VMware tools 12.5.1 that addressed this issue.
Article ID: 000034161
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
