PROBLEM
ArcGIS Server service is running but the the ArcSOC instances and javaw services are not up
First Published: August 14, 2025
Last Published: August 14, 2025
ArcGIS Server site is inaccessible despite the service running. However, the ArcSOC instances and javaw services are not up.
Cause
The lack of disk space in the installation path has caused the corruption of the server.xml file.
Solution or Workaround
    Replace the server.xml file
    1. Navigate to the following directory:
    <ArcGIS Server Installation Directory>\framework\runtime\tomcat\conf
    Usually, the ArcGIS Server installation directory is:
    C:\Program Files\ArcGIS\Server
    1. Replace the existing server.xml with another one from a functional environment of the same version of ArcGIS Server.
    2. Restart the ArcGIS Server service.
    Edit server.xml
    1. Open the server.xml file in:
    <ArcGIS Server Installation Directory>\framework\runtime\tomcat\conf.
    1. Search for certificateKeyAlias paramater and ensure that it is set to the default 'SelfSignedCertificate' (certificateKeyAlias="SelfSignedCertificate"). Directly replacing server.xml file might not work if the certificate alias name is mismatched.
    Ensure that the disk always has enough space. ArcGIS Server requires a minimum of 10 GB of available disk space. Refer to the link in the Related Information section for the system requirements of ArcGIS Server. You may choose the version and OS relevant to your ArcGIS Server in the 'Other Versions' dropdown below the title.
    Article ID: 000036483
    Software:
    • ArcGIS Server
    Get support with AI
    Start chatting now
    Related Information
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
