PROBLEM
ArcGIS Server .NET Web Applications display a red 'X' instead of the image for a task result
After executing a task in an ArcGIS Server .NET Web Application, a red 'X' is displayed near the feature in the map display, in place of the image that is set to display for a layer's result symbol.
Cause
The path to ArcGIS Server's Marker Symbols directory is broken or nonexistent. By default, this folder is found in the following location:
<application root directory>\aspnet_client\ESRI\WebADF\MarkerSymbols
Solution or Workaround
There are two methods to resolve this problem:
  • Re-create the ArcGIS Server Instance that is serving the application. For more information about re-creating the ArcGIS Server instance, please refer to the articles in the Related Information section below.
  • Copy the ESRI folder from the <application root directory>\aspnet_client folder on a working application server, and paste it into the aspnet_client folder for the application server that is not working correctly.
Article ID: 000010722
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
