PROBLEM
ArcGIS Server 9.2 on Linux does not restart automatically after the server machine is rebooted
ArcGIS Server 9.2 on Linux does not restart automatically after the server machine is rebooted.
Cause
The startup scripts for ArcGIS Server 9.2 are not placed at the correct system run level.
Solution or Workaround
  1. Log in as a root user and delete the link named 'S99serverobjectmanager' from the following location:
    /etc/rc2.d
  2. Delete the link named 'S99mwcoreservices' from the following locations:
    /etc/rc3.d
    /etc/rc5.d
  3. Delete the link named 'K70mwcoreservices' from the following locations:
    /etc/rc0.d
    /etc/rc1.d
  4. Create a symbolic link in /etc/rc3.d and /etc/rc5.d
    named 'S99serverobjectmanager' that points to the following script:
    arcgisserver_install_location/servercore/.Server/agsserver
    For example:
    Code:
    > ln -s arcgisserver_install_location/servercore/.Server/agsserver S99serverobjectmanager
  5. Create a symbolic link named 'K99serverobjectmanager' to arcgisserver_install_location/servercore/.Server/agsserver in following locations:
    /etc/rc0.d
    /etc/rc1.d
    For example:
    Code:
    > ln -s arcgisserver_install_location/servercore/.Server/agsserver K99serverobjectmanager
Article ID: 000009362
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
