DEPRECATION
ArcGIS Roadway Reporter
Last Published: October 11, 2024
We are deprecating the ArcGIS Roadway Reporter web application and replacing it with a new workflow that leverages ArcGIS Pro and the geoprocessing framework. This replacement workflow enables customers to configure and automate the generation of reporting data products that are useable in commercial off-the-shelf reporting packages. Examples of these include Microsoft PowerBI, Crystal Reports, Business Objects, SQL Server Reporting Services, and ArcGIS Pro’s report creation tools.
The deprecation is largely due to the retirement of ArcGIS API for JavaScript version 3.x and ArcGIS Enterprise 10.8.1 entering mature support.
Recommendation
ArcGIS Roads and Highways customers using the ArcMap-based extension will need to upgrade to ArcGIS Pro 3.5 and ArcGIS Enterprise 11.5 (or later) and deploy the new reporting workflow.
ArcGIS Roads and Highways currently using ArcGIS Pro-enabled services workflows will need to upgrade to ArcGIS Pro 3.5 and ArcGIS Enterprise 11.5 (or later) and deploy the new reporting workflow.
Article ID: 000033828
Software:
  • Roadway Reporter for Roads and Highways
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
