PROBLEM
ArcGIS Pro fails to open with the following error, “To run this application, you must install missing frameworks for .NET.”
First Published: January 11, 2023
Last Published: July 25, 2025
Launching ArcGIS Pro 3.0.3 and subsequent 3.0.x patch versions returns the following error:
 “To run this application, you must install missing frameworks for .NET. Would you like to download it now?”
Cause
ArcGIS Pro 3.0.3 and subsequent 3.0.x patch versions require a minimum of Microsoft .NET Desktop Runtime 6.0.5 – Windows x64, as indicated in the System Requirements. If the machine has .NET 7.x.x installed without the minimum required version from the .NET 6 family installed, this error is received.
At ArcGIS Pro 3.0.x this error may be presented after installation. However at ArcGIS Pro 3.1 and later, this error may be returned during install as it is a pre-installation requirement in those later versions.
Solution or Workaround
Download and install the latest available version of Microsoft .NET 6.x.x Desktop Runtime – Windows x64 from Microsoft: Download .NET 6.0, as shown in the image below.
Article ID: 000029200
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
