ERROR
When creating new features such as points, lines, or polygons with the following options:
The operation fails and the following error is returned:
Error: Failed to create <Feature Class>. Value doesn’t fall within Domain: <Domain>
This error arises from the initial configuration of the feature. When creating a new feature class, if a field is set up to use a domain, disallows null values, and lacks a default value, encountering the this error is expected. Essentially, the system notifies users that the provided value does not fall within the specified domain. If a domain is assigned to a field, the default value for the field must be selected from the domain values.
Once the error appears in the Create Features window, follow these steps:
Article ID: 000031743
Get help from ArcGIS experts
Start chatting now
