ERROR
ArcGIS Pro 3.5.2 Data Interoperability tools fail to launch on Citrix with error: Qt6Core_fme.dll missing
First Published: September 24, 2025
Last Published: September 24, 2025
Error Message
After upgrading Citrix workstations to ArcGIS Pro 3.5.2, attempts to launch the Data Interoperability tools extension fail. Users receive an error referencing a missing Qt6Core_fme.dll file. Reinstalling, repairing, or modifying the installation does not resolve the issue.
example error message
Cause
ArcGIS Pro 3.5.x includes an updated version of FME (2025.0) for the Data Interoperability extension. This version of FME is not supported on Windows Server 2016. The last version of FME supported on Windows Server 2016 was FME 2024.2. As a result, ArcGIS Pro 3.5.2 Data Interoperability Tools cannot run properly in this environment.
This is a known issue, see BUG-000179196: The ArcGIS Pro 3.5 Data Interoperability extension fails on Windows Server 2016
Solution or Workaround
To resolve this issue, use one of the following options:
  • Upgrade the operating system to Windows Server 2019 or later. This allows ArcGIS Pro 3.5.2 and the bundled FME 2025.0 runtime to function as expected.
  • Roll back ArcGIS Pro and the Data Interoperability extension to version 3.4 (or another compatible release). ArcGIS Pro 3.4 uses an earlier FME runtime that is supported on Windows Server 2016.
Article ID: 000037977
Software:
  • ArcGIS Pro
  • ArcGIS Data Interoperabilityx
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
