PROBLEM
ArcGIS Pro 3.3 crashes when a new project is created with a map while an existing install of an ArcGIS Pro 3.2 language pack is installed. The first indication of the impending crash is a warning window that pops up to notify the user that the language pack is not compatible with the current version of ArcGIS Pro, as shown in the image below. After that, the program crashes if the user creates a new project with a map. Subsequent launches of ArcGIS Pro will not crash after the first instance unless the user manually changes the language pack again to ArcGIS Pro 3.2 language packs—this should be avoided.
There are several options to prevent this crash.
Article ID: 000032550
Get help from ArcGIS experts
Start chatting now
