ERROR
Portal for ArcGIS connecting to SQL Server: Failure to access the DBMS server[ ]
Last Published: August 13, 2024
Error Message
When Portal for ArcGIS attempts to connect with a SQL Server database, the following error is returned:
Failure to access the DBMS server[]
Cause
This error is due to SQL Server disabling the Protocol Name for Named Pipes and TCP/IP.
Solution or Workaround
  1. On the server machine installed with SQL Server. Ensure that the Protocol Name for Named Pipes and TCP/IP is enabled, as shown in the image below. This setting can be changed in SQL Server Configuration Manager.
  1. Restart the SQL Server Services.
Article ID: 000033361
Software:
  • ArcGIS Pro
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
