Frequently asked question
Does ArcGIS support Oracle DML redirection or database links?
Last Published: February 6, 2025
ArcGIS does not support DML redirection, an Oracle Active Data Guard feature, due to underlying user-defined types (UDTs) restrictions with remote databases. In Enterprise Geodatabases, ST_Geometry and SDO_Geometry are user-defined types used to store spatial data within an Oracle database. User-defined types in database links are a known restriction in Oracle, and by extension DML redirection which uses transparent database links. See: 2.1.9 Restriction on Using User-Defined Types with a Remote Database.
DML redirection uses a database link to connect to a remote database, and when DML queries on user-defined types are sent, the following error is returned:
ORA-22804 remote operations not permitted on object tables or user-defined type columns
Queries that contain remote databases and references to a user-defined type will return a different error:
ORA-00942: table or view does not exist.
These errors are due to the remote database's inability to interpret and implement the local database type. There are further complications to user-defined types (UDTs), including the use of local variables in PL/SQL code and remote procedure calls, which ArcGIS relies heavily upon for versioning operations with the database.
While there may be some simple database transactions that work, particularly with non-spatial data, much of the ArcGIS enterprise geodatabase functionality is impacted by this known restriction in Oracle's software.
Article ID: 000032606
Software:
  • ArcGIS Desktop
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
