HOW TO
The OAuth configuration information detailed in this article applies to ArcGIS Enterprise versions 11.0 and 11.1. With these versions, additional configuration is required to support the OAuth login workflow in the ArcGIS Mission Responder mobile application.
However, if you are operating ArcGIS Enterprise 11.2 or higher, no additional configuration is required to support this capability.
In ArcGIS Mission Responder, Esri offers browser-based OAuth authentication for signing into an ArcGIS Enterprise account. To enable web-based OAuth login with these earlier versions of Enterprise, a user with administrative privileges must complete the configuration steps below in the Portal Admin app.
As an administrator user:
"appId":"arcgisMissionResponder",
"redirectURIs":["urn:ietf:wg:oauth:2.0:oob","arcgis-responder://auth/"]
Once the change has been saved, the browser-based OAuth login workflow to connect to ArcGIS Enterprise using the ArcGIS Mission Responder mobile application is enabled.
A Portal restart is not required after making this configuration change.
Article ID: 000032043
Get help from ArcGIS experts
Start chatting now
