DEPRECATION
ArcGIS Mission
First Published: September 16, 2026
Last Published: September 16, 2026
Esri is announcing the deprecation of ArcGIS Mission and all its components including ArcGIS Mission Server, ArcGIS Mission Manager, and ArcGIS Mission Responder with ArcGIS Enterprise 12.3 (Q2 2027) as the final release.
Between now and the release of ArcGIS Mission 12.3, there will be no new features, enhancements, or promotional updates to ArcGIS Mission. However, once released, ArcGIS Mission 12.3 will be supported under Esri's standard lifecycle, with patches, security updates, and technical support available through Q2 2031.
Recommendation
If your organization currently relies on ArcGIS Mission for operational workflows, no immediate action is required. You can continue to use your current version of ArcGIS Mission, and you will have the option to upgrade to ArcGIS Mission 12.2 (Q4 2026) and 12.3 (Q2 2027) as they become available. Support will continue through 2031.
However, we recognize that your operational needs extend beyond 2031, and there is no single migration path that fits all use cases. Organizations use ArcGIS Mission in varied ways, some for real-time field coordination, others for command-and-control operations, and others for situational awareness and after-action review. As a result, the right path forward will differ based on your specific workflows, technological environment, and organizational requirements.
We encourage you to:
  • Evaluate: Review your deployment and evaluate your current use of ArcGIS Mission and identify which capabilities are most critical to your operations.
  • Plan: With support available through 2031, you have time to evaluate alternatives and transition at a pace that works for your organization. Explore the broader ArcGIS platform for capabilities that support your workflows.
  • Engage: Contact your Esri account manager and/or professional services contact for individualized planning and guidance to discuss your specific needs and explore options tailored to your organization. We are committed to supporting you through this transition.
Article ID: 000043633
Software:
  • ArcGIS Mission
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
