BUG
A stability issue has been identified when attempting to access web maps in the ArcGIS Field Maps mobile application that were originally generated via the ArcGIS for Excel add-in. The current workflow involves mapping the .csv data with latitude and longitude coordinates, adding it as an Excel layer, and utilizing the “Share | Export” function to create the web map. Although the export process completes, the Field Maps application consistently crashes upon opening these specific maps.
The bug lies in web maps created using ArcGIS for Excel. If these web maps are opened in an ArcGIS Enterprise portal, they load successfully in the Map Viewer, however, when trying to open the same web map in the ArcGIS Field Maps mobile application, it fails and the mobile application crashes.
As a workaround, follow these steps:
The workaround at this time to stop Field Maps from crashing is to navigate to the ArcGIS Enterprise portal and save the web maps after each update in ArcGIS for Excel.
Article ID: 000039796
Get help from ArcGIS experts
Start chatting now
