ERROR
ArcGIS Enterprise 11.0: Failed to install data pack United States (Esri 2024)
First Published: November 13, 2024
Last Published: November 13, 2024
Error Message
Install of United States 2024 data pack fails on ArcGIS Enterprise 11.0, and returns the following errors:
Failed to install metadata for United States (Esri 2024).
Failed to install data pack United States (Esri 2024).
Cause
The United States Esri 2024 data pack is missing a table that is expected in ArcGIS Enterprise version 11.0 and earlier.
Solution or Workaround
Install a newer version of ArcGIS Enterprise or modify the loading script.
  • Install ArcGIS Enterprise version 11.1 or newer.
  • Modify the loading script (createAdditionalLayers.py) by commenting out lines 137 and 138, shown below, and reinstalling the data. The script is located where your ArcGIS Server is installed (/arcgis/server/tools/geoenrichment/MetadataUpload).
#if not tableExists(dataDbContext.curs, dataDbContext.schemaName, geomTableName):
#           raise Exception("Table '{0}' for AnnualTrends layer wasn't found.".format(geomTableName))
Article ID: 000034162
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
