PROBLEM
ArcGIS Data Store validation fails after successful configuration with ArcGIS Server
First Published: April 20, 2026
Last Published: April 20, 2026
ArcGIS Data Store may configure successfully but fail validation in ArcGIS Server Manager, even after standard troubleshooting steps have been taken, such as verifying permissions, connectivity, and firewall rules.
This can lead to confusion, as the configuration appears successful while the Data Store remains unusable for hosting or publishing operations. This behavior may occur even when no clear errors are reported during the configuration process.
Cause
The configuration process verifies that ArcGIS Data Store is installed and registered with the ArcGIS Server site.
The validation process performs additional checks, including connectivity, authentication, and communication between ArcGIS Server and the Data Store.
In some cases, underlying environment or system-level constraints may prevent successful validation, even when configuration and standard troubleshooting steps appear correct.
Solution or Workaround
Verify that all standard troubleshooting steps have been completed:
  • Confirm the ArcGIS Data Store service is running under the correct service account.
  • Ensure required permissions are applied to ArcGIS Server and Data Store directories.
  • Verify network connectivity and required ports between ArcGIS Server and the Data Store.
  • Confirm no firewall or endpoint protection rules are blocking communication.
If validation continues to fail after completing these steps, further investigation into the underlying system or environment may be required. In some cases, redeploying the Data Store in a clean environment can help resolve issues caused by environmental constraints.
When to suspect an environment-related issue
  • The Data Store configures successfully but consistently fails validation.
  • The issue persists after verifying the service account, permissions, and connectivity.
  • Re-install or re-registration does not resolve the issue.
  • There are no clear errors pointing to a specific misconfiguration.
Article ID: 000041055
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
