BUG
ArcGIS Data Store configuration wizard fails to load in Chrome 67
Last Published: July 9, 2025
The ArcGIS Data Store configuration wizard fails to load in Chrome 67.
A blank white page is returned, and the following error is recorded in the browser's developer console.
Uncaught ReferenceError: normal is not defined
    at eval (eval at l (bootstrap.js:475), <anonymous>:1:1)
    at Object.load (bootstrap.js:475)
    at Za (dojo.js:21)
    at dojo.js:17
    at a (dojo.js:2)
    at ib (dojo.js:17)
    at fa (dojo.js:18)
    at ga (dojo.js:20)
    at dojo.js:20
This issue can only be reproduced at version 10.6.
Cause
This is caused by a defect in ArcGIS Data Store: BUG-000114350: ArcGIS Data Store configuration wizard fails to load in Chrome 67.
Workaround
There are two workarounds to this issue.
  1. Use a different browser to configure the ArcGIS Data Store.
  2. Use the command line to configure the ArcGIS Data Store. Steps are documented in the following article: ArcGIS Enterprise Help: Use the configuredatastore utility to create a data store
Article ID: 000018486
Software:
  • ArcGIS Data Store
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
