BUG
If the javax.faces.STATE_SAVING_METHOD is set to "client" as shown below in the web.xml file, the ArcGIS 9.3 Service Pack 1 (SP1) Java ADF application containing EditingTask does not work in a Mozilla Firefox browser.
<context-param>
<param-name>javax.faces.STATE_SAVING_METHOD</param-name>
<param-value>client</param-value>
</context-param>
When opening the above application in Firefox browser, it generates the following exception in the web server logs and it displays “The application encountered an error. Please check server logs for additional information.” message in the browser.
- Unexpected end of ZLIB input stream
java.io.EOFException: Unexpected end of ZLIB input stream
at java.util.zip.InflaterInputStream.fill(InflaterInputStream.java:216)
at java.util.zip.InflaterInputStream.read(InflaterInputStream.java:134)
at java.util.zip.GZIPInputStream.read(GZIPInputStream.java:87)
at java.io.ObjectInputStream$PeekInputStream.read(ObjectInputStream.java:2213)
at java.io.ObjectInputStream$PeekInputStream.readFully(ObjectInputStream.java:2226)
at java.io.ObjectInputStream$BlockDataInputStream.readUTFBody(ObjectInputStream.java:2963)
at java.io.ObjectInputStream$BlockDataInputStream.readUTF(ObjectInputStream.java:2764)
at java.io.ObjectInputStream.readString(ObjectInputStream.java:1567)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1296)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1908)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1832)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1719)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1305)
at java.io.ObjectInputStream.readArray(ObjectInputStream.java:1634)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1299)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:348)
at com.sun.faces.renderkit.ResponseStateManagerImpl.getTreeStructureToRestore(ResponseStateManagerImpl.java:154)
at com.sun.faces.application.StateManagerImpl.restoreTreeStructure(StateManagerImpl.java:374)
at com.sun.faces.application.StateManagerImpl.restoreView(StateManagerImpl.java:260)
at com.sun.faces.application.ViewHandlerImpl.restoreView(ViewHandlerImpl.java:250)
at com.sun.faces.lifecycle.RestoreViewPhase.execute(RestoreViewPhase.java:177)
at com.sun.faces.lifecycle.LifecycleImpl.phase(LifecycleImpl.java:245)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:110)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:213)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at com.esri.adf.web.util.ADFFilter.doFilter(Unknown Source)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at com.esri.adf.web.util.ADFSessionTimeoutFilter.doFilter(Unknown Source)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
This is a known issue.
Article ID:000010370
Get help from ArcGIS experts
Download the Esri Support App
