PROBLEM
ArcCatalog loses focus and freezes when opening the metadata editor
When opening the metadata editor, ArcCatalog seems to lose focus and freezes.
Cause
The metadata editor may have opened off the viewable screen.
▪ In ArcGIS 10, this should only be a potential problem when using the FGDC Metadata Editor add-in.
Solution or Workaround
Use keyboard combinations to bring the metadata editor window back onto the viewable screen.
  1. To verify that the editor window has opened off screen, press Alt+F4 on the keyboard. If a confirmation dialog box appears, click Yes.
  2. Launch the metadata editor again. This time, press Shift+Alt+Spacebar, then the letter 'M'. Use the arrow keys until the editor window appears back on screen, then press Enter.
Article ID: 000010404
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
