ERROR
When using a Web Mapping Application built with the 9.3 .NET Web ADF, clicking the FullExtent button or using the ZoomTo/PanTo options on a task result can crash the application with the following error:
"Application Error
Object reference not set to an instance of an object.
ESRI.ArcGIS.ADF.Web.Geometry.TransformationParams..ctor(Envelope extent,
Int32 viewWidth, Int32 viewHeight, Double mapRotationInDegrees,
TransformationDirection direction, SpatialReference spatialReference) at
ESRI.ArcGIS.ADF.Web.UI.WebControls.OverviewMap.getTransformationParams
(TransformationDirection direction)"
The OverviewMap's OverviewMapResource property is not set to a valid resource item.
This can easily occur when the map resource item that the OverviewMap is set to display is renamed or deleted in the MapResourceManager.
Article ID:000010204
Get help from ArcGIS experts
Download the Esri Support App
