ERROR
While trying to print with ArcPress, the following error may be returned:
"AppESRIPrintLocal.EXE has encounters a problem and needs to close."
The current user does not have read/write access to C:\Windows\System32\Spool\PRINTERS. In some cases, the AppESRIPrintLocal.EXE file also needs to be registered.
Contact the System Administrator if there are difficulties setting permissions.
Code:
<ArcGIS_install_location>\appesriprintlocal.exe /regserver
If ArcGIS has been installed to C:\Programs Files\ArcGIS, this command may fail. Open an MS-DOS prompt, change the directory to the ArcGIS\bin install location and run 'appesriprintlocal.exe /regserver'.
Article ID:000008070
Get help from ArcGIS experts
Download the Esri Support App
