PROBLEM
Unable to create a file geodatabase using a mapped drive in ArcGIS Pro
First Published: December 24, 2024
Last Published: August 20, 2025
When a folder is shared to an organization, for example, //servername/datadir/data/workdir, and the folder is mapped as a new drive in local machine, for example, Z:/data/workdir, the file geodatabase cannot be created using ArcGIS Pro. Additionally,
  • When attempting to create the file geodatabase, the process gets directed to renaming the folder without any .gdb file being created, as shown in the next two images.
  • A feature class cannot be created either, as shown in the next image.
Cause
  • The mapped drive path was being used while accessing the shared folder.
  • The created file geodatabase is not updated to the actual shared location as it is mapped locally in the machine (Z:). This in turn creates a broken geodatabase, as well as faulted feature datasets or feature classes.
Solution or Workaround
  1. Open a project in ArcGIS Pro.
  2. Check if the Catalog pane is enabled or not. If not, enable the catalog pane from View > Catalog Pane.
  3. Right-click the folder and click Add Folder Connection.
  4. In the ribbon, add the actual shared path (//servername/datadir/data/) instead of mapped path (Z:/datadir/data).
  5. Click on the folder to be added.
  6. Create the file geodatabase and feature dataset/classes.
Recommendation
Save the project to create an index for the added folders. This index makes accessibility of the folders faster.
Article ID: 000034367
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
