ERROR
An unexpected error has occurred when publishing a map, please check the settings and try again
Error Message
When publishing a map with the ArcGIS Publisher extension, the following error message appears:
"An unexpected error has occurred when publishing a map, please check the settings and try again".
Cause
The data frame is grouped with images and text graphics in the layout.
Solution or Workaround
Ungroup the data frame from images and text graphics in the layout. Republish the map.
Article ID: 000009767
Software:
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
