HOW TO
This document describes how to allow an .apr to be opened by only one user at a time via Avenue.
Code:
'Startup Script --------------------------------------
ps = av.getproject.getfilename.clone
psd = ps.stripfile
'MsgBox.Info(ps.AsString,"")
ptitleapr = av.GetProject.GetWin.GetTitle.Clone
ptitle = ptitleapr.AsString.Substitute(".apr","apr")
text_file = "\"+ptitle+".txt"
thefilestr = psd.AsString+text_file.AsString
_textfilename = thefilestr.AsString.AsFileName
checkfile = FileName.FindInSystemSearchPath (_textfilename.AsString)
if (checkfile <> nil) then
theLineFile = linefile.make(_textfilename,#FILE_PERM_READ)
thelist = List.Make
numlines = theLineFile.GetSize
source = theLineFile.Read( theList,numlines )
a = theList.count
pos = theLineFile.SetPos (0)
info_list = list.make
for each l in theList
theline = theLineFile.ReadElt
info_list.Add(theline)
end
MsgBox.Warning(info_list.Get(0).AsString++
"is currently using this project on"++info_list.Get(1).AsString+NL+
"Login date and time:"++info_list.Get(2).AsString+NL+
"Check with the above user. Closing the project","W A R N I N G !!")
av.run("Project.Close",nil)
else
' DETERMINE IS OPERATING SYSTEM IS WINDOW BASED
' SET %SystemRoot% IF WINDOWS NT OR 95
OSvar = System.GetOSVariant
if (OSvar = #SYSTEM_OSVARIANT_MSWNT) then
wd = system.GetEnvVar("windir")
_WinSysDir = wd+"\system32\"
elseif (OSvar = #SYSTEM_OSVARIANT_MSW95) then
else
MsgBox.Warning("This project is designed for use" +NL+
"by WindowsNT and Windows95 PCs.","Stop")
av.GetProject.Close
end
' DETERMINE THE USER LOGIN NAME
'Make the DLL object
dllAdvAPI32 = dll.make((_WinSysDir + "advapi32.dll").AsFileName)
'Make the DLLProc object
dpGetUserNameA = dllproc.make(dllAdvAPI32, "GetUserNameA",
#DLLPROC_TYPE_INT32,{#DLLPROC_TYPE_STR, #DLLPROC_TYPE_PINT32})
'Make the string buffer
uname = String.MakeBuffer(12)
buflen = 10
retValue = Number.MakeNull
'Call the function which returns the username to the buffer
retValue = dpGetUserNameA.Call({uname, buflen})
tf = LineFile.Make(_textfilename, #FILE_PERM_APPEND)
mystr = Uname.AsString
'MsgBox.Info(mystr.AsString,"")
tf.WriteElt(mystr)
' DETERMINE THE COMPUTER NAME
dllKernel32 = dll.make((_WinSysDir + "kernel32.dll").AsFileName)
dpGetComputerNameA = dllproc.make(dllkernel32, "GetComputerNameA",
cname = String.MakeBuffer(12)
buflen = 10
retValue = dpGetComputerNameA.Call({cname, buflen})
compname = cname.AsString
'MsgBox.Info(compname,"")
tf.WriteElt(compname)
d = Date.Now.AsString
tf.WriteElt(d)
tf.close
end
'END OF STARTUP SCRIPT -------------------
Code:
'ShutDown Script -------------------------------------
else
av.GetProject.Close
end
buflen = 10
buflen = 10
checkfile2 = FileName.FindInSystemSearchPath (_textfilename.AsString)
if (checkfile2 <> nil) then
theLineFile2 = linefile.make(_textfilename,#FILE_PERM_READ)
thelist = List.Make
numlines = theLineFile2.GetSize
source = theLineFile2.Read( theList,numlines )
a = theList.count
pos = theLineFile2.SetPos (0)
theline = theLineFile2.ReadElt
end
end
if (info_list.Count > 0) then
user = info_list.Get(0).AsString
comp = info_list.Get(1).AsString
else
return nil
end
if ((mystr = user) and (compname = comp)) then
_theLineFile = nil
_tf = nil
theLineFile2 = nil
av.PurgeObjects
File.Delete(_textFileName)
else
end
'END OF SHUTDOWN SCRIPT ------------------
Warning:
Users should never open two versions of the application, with the same project file on their local machine. This could allow for corruption of the project file.
Get help from ArcGIS experts
Download the Esri Support App
