PROBLEM
After installing ArcGIS Solutions for ArcGIS Enterprise, the Solutions Gallery is empty
Last Published: August 4, 2025
When ArcGIS Solutions for ArcGIS Enterprise is installed with ArcGIS Enterprise, the ArcGIS Solutions gallery appears empty.
ArcGIS Solutions for ArcGIS Enterprise is only available for install on ArcGIS Enterprise 10.9 and 10.9.1 (Windows, Linux).
Cause
There may be two causes for this issue:
  • During the installation process, Solution Item content is added to ArcGIS Enterprise. These items are not being recognized by ArcGIS Enterprise.
  • Encountering an existing defect.
Solution or Workaround
Perform a reindex on the ArcGIS Enterprise portal.
  1. Sign in to the ArcGIS Enterprise Portal Administrator Directory with administrator credentials.
  2. Navigate to System > Indexer > Reindex.
  3. Perform a full reindex.
Graphical user interface, text, application, email  Description automatically generated
This causes the ArcGIS Enterprise portal instance to restart.
If you’re still encountering this issue after performing a reindex, please contact Esri Technical Support for further assistance.
Encountering an existing defect:
Article ID: 000027316
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
