PROBLEM
Adobe Illustrator can not save ArcMap .ai file
Adobe Illustrator returns the following warning message when trying to save an ArcMap generated .ai file:
"You are saving this document in Adobe Illustrator 3.0/3.2 format. Saving this document in an older format may disable some editing features when the document is read back in."
Cause
ArcMap 8.x exports an earlier specification of the Adobe Illustrator (.ai) file format. Many features in the newer versions of Illustrator are not supported in this specification.
Solution or Workaround
In Illustrator, use File > Save As... to save the file. In the dialog box, select a more recent specification, such as Illustrator 9.0 or 10.
To use the Adobe Illustrator (.ai) export format in 8.1, download the ArcGIS 8.1 Service Pack 1.
Article ID: 000004064
Software:
  • ArcMap 8 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
