ERROR
Adding a data table with SQL Query wizard causes a Segmentation Violation
Last Published: April 26, 2020
Error Message
This error occurs when using the SQL Query wizard to add a database table:
Error:
"Segmentation Violation"
Cause
This is a known issue with Database Access version 2.1c.
Solution or Workaround
Use the Add Database Table dialog box instead of the SQL Query wizard.
  1. Load the Database Access extension.
  2. Make the Project window active.
  3. Click Database Table Preferences from the Project menu.
  4. Select Add Database Table and click OK.
    [O-Image] Add Database Table dialog box
  5. Select Add Database Table from the Project menu.
Article ID:000004900
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
