HOW TO
The ArcGIS Flight app is registered and supported with ArcGIS Enterprise 10.8.1 portals and higher. If working with ArcGIS Enterprise versions 10.6.1 to 10.8, the following procedure is required to add the ArcGIS Flight app as registered applications within an ArcGIS Enterprise portal.
Note: This guide is not intended to allow publishing of content from the Site Scan Manager for ArcGIS web application to ArcGIS Enterprise. To enable this, request a connection from your Esri Customer Success Manager or Technical Support and provide them with your Enterprise portal URL and App ID.
Use the following steps to add ArcGIS Flight app as registered apps to ArcGIS Enterprise 10.6.1 and later:
https://webadaptorhost.domain.com/webadaptorname/sharing/rest
Note: The URL below must be manually typed into the address bar and cannot be accessed by clicking through the Sharing/REST web interface. In the following URL, [username] should be replaced with the aforementioned administrative user.
https://webadaptorhost.domain.com/webadaptorname/sharing/rest/content/users/[username]
["urn:ietf:wg:oauth:2.0:oob", " sitescan3dr://arcgisauth"]
https://webadaptorhost.domain.com/webadaptorname/portaladmin
Article ID: 000025292
Get help from ArcGIS experts
Start chatting now
