DEPRECATION
Add Preset Gallery Deprecation
First Published: March 31, 2022
Last Published: March 31, 2022
The Add Preset gallery is deprecated and will be removed in ArcGIS Pro 3.0.
Recommendation
There should be no major impact to customer workflows. Preset layers can continue to be used in ArcGIS Pro 2.x, and they remain compatible in online maps.
In ArcGIS Pro 3.0, users can add a Subtype Group Layer or an elevation/ground layer through the Add Data menu. Maps with existing layers created from preset types can be used as-is in ArcGIS Pro 3.0 without modifying the layers’ symbology. Users who need to modify preset layer symbology will be presented an option to Convert the layer(s) in the ArcGIS Pro 3.0 Symbology pane. Converting allows users to modify symbology, as the layers will contain a regular simple renderer or regular unique value renderer after conversion.
Article ID: 000027469
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
