HOW TO
Add distance and direction to an existing line feature
First Published: May 5, 2016
Summary
Instructions provided describe how to add distance and direction to an existing line feature.
Procedure
To add and maintain COGO descriptions in a feature class, the attribute tables need to have certain fields. Add COGO fields to the feature class using the Create COGO Fields tool in ArcCatalog.
  1. In ArcCatalog, right-click the Standard toolbar and select Customize.
  2. Select the Commands tab and then type 'COGO Fields' in the Show box. The available geodatabase tools appear on the right side of the panel.
  3. Drag and drop the Create COGO Fields button onto any of the ArcCatalog toolbars.
  4. In the Catalog tree in ArcCatalog, select the line feature class on which to add COGO fields.
  5. Click the Create COGO Fields button. A message dialog box appears showing that the following fields have been added: Direction, Distance, Radius, Delta, Tangent, ArcLength, and Side.
  6. In ArcMap, use the Edit tool to select one or more line features.
  7. Click Update COGO Attributes on the COGO toolbar.
Article ID: 000008998
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
